1 - 11 of 11 Posts
P4x4 Vendors
Diode Dynamics is excited to introduce our Stage Series LED Ditch Light Kit for the 2015-2021 Ford F-150!
The Stage Series LED Ditch Light Kit for the 2015-2021 Ford F-150 allows you to easily mount two SS3 or SSC2 Pods above the hood. These application-specific brackets were CAD-designed to install using factory mounting points. No cutting or drilling required! This kit features a low profile design while minimizing glare, and will not interfere with raising or lowering the hood.
Built to last. The brackets in this kit are constructed out of thick-gauge stainless steel. Unlike other options made out of mild steel, these brackets are full stainless steel and won't corrode over time. With their thick-gauge construction, you also won't experience any vibration or bouncing while driving.
Focused: Most LED pods on the market, even certain premium options, use outdated technology like reflectors or simple lenses that lose light internally and to glare. By comparison, our custom-engineered total internal reflection (TIR) optic collects all of the light from the LED chips, drastically reducing wasted light and improving total efficiency.
While other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the SS3 and SSC2 serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the Stage Series Pod is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
Click HERE to check out the Stage Series LED Ditch Light Kit for 2015-2021 Ford F-150!
SSC2 Pro LED Pod - Combo Beam Pattern
Functional output. All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern. No matter what your auxiliary lighting needs are, there is a Stage Series optic for you!
  • Combo combines both the Driving and Flood optics. The SS3 shines light downrange in a focused, rectangular 65x25 degree pattern, while the SSC2 shines light downrange in a 40x20 degree pattern. The combo lens features a flood optic on one side and a driving optic on the other.
White or Yellow. All Stage Series LED pods are available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road. We also offer replacement lenses that allow you to change the color or optic of your SS3 or SSC2 Pods.
Sport or Pro. Stage Series LED pods are available at two different power levels. Both options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. However, the Pro option is double the amount of total power!
Backlight Functionality. All SSC2 Ditch Light Kits include a distinctive Amber backlight feature. The SSC2's backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
Bolt-On Installation: The thick-gauge stainless steel brackets in this kit were CAD-designed to utilize existing mounting points for a bolt-on installation - there is no cutting or drilling required!
Each kit will include:
  • Two (2) SS3 or SSC2 Standard LED Pods
  • Two (2) Ditch light brackets
  • Two (2) SS3 or SSC2 Mounting brackets
  • One (1) Heavy-duty dual output wiring harness
  • Mounting hardware
  • Mounting guide
See how to install our Stage Series LED Ditch Light Kit for 2015-2021 Ford F-150 below!
Customizable: If you鈥檙e looking to change the output color, add a layer of protection, or simply add some extra style to your SS3 LED pods, our snap-on covers are a great option. Like our scratch-resistant SS3 lenses themselves, the SS3 Pod Covers are made with a strong polycarbonate plastic, to protect against whatever the road throws your way.
Proven Reliability: Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email [email protected].
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking,
John C.
Diode Dynamics
P4x4 Vendors
Discussion Starter · #2 ·
Our July 4th Sale starts NOW! Today through Thursday, 7/8/2021, save 15% on all LED upgrades, including our newly released SSC1 LED Pod, by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive an exclusive Diode hat!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Thursday, 7/8/2021. Cannot be combined with other coupon codes.
P4x4 Vendors
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 7/8/2021, you can use coupon code "JULY4" at checkout for 15% off your entire order of lighting upgrades, including our newly released SSC1 LED Pod! Don't wait, this sale ends TONIGHT!
Plus, all orders over $300 will receive a free Diode hat!
John C.
Diode Dynamics
P4x4 Vendors
Now's the time to upgrade your ride! Our Labor Day Sale is going on NOW! Save 15% sitewide, including our SS3/SSC2 ditch light kits, by entering coupon code "LABOR" at checkout! And, all orders over $300 will receive a free Diode flag tee! Sale ends Friday, 9/10/2021.
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/10/2021.
Sale excludes preorders.
P4x4 Vendors
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Stage Series Ditch Light Kits, with coupon code "LABOR" at checkout! Plus, get a free Diode flag tee when you spend $300! HURRY, this sale ends TONIGHT!
John C.
Diode Dynamics
P4x4 Vendors
Have you guys seen the Diode Dynamics product launch from SEMA 2021?
Due to high demand, SS3 LED pods will soon include a backlight feature!
6:03 - SS3 Backlit
If you have any questions, I'll be glad to help!
John C.
Diode Dynamics
P4x4 Vendors
Don't miss your chance to save 15% off your entire order of lighting upgrades, including our Stage Series Ditch Light Kits, with coupon code "BF21" at checkout! Plus, get a free Diode Dynamics Stage Series long sleeve shirt when you spend $500! HURRY, this sale ends TONIGHT!
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST | Tuesday, 11/30/2021.
Cannot be combined with other coupon codes.​
P4x4 Vendors
Discussion Starter · #10 ·
P4x4 Vendors
Discussion Starter · #11 ·
"Are your SS3 LED pods are able to melt ice and snow built up?"
Yes, our SS3 Pro and SS3 Max power levels are able to melt snow and ice build-up!
Unfortunately, our SS3 Sport doesn't produce enough heat to melt snow and ice build-up.
Have questions regarding our Stage Series LED pods? Just let us know, we'll be happy to help!
1 - 11 of 11 Posts
