Did alot of reading on the vette mc conversion simple enough everything went together without a problem(at least going into a range rover). Bleed the brakes and the pedal is hard but the brakes arent locking up. I am running 4 piston front calipers and 2 piston rears. I am useing the modified jeep prop valve(took the spring and o ring out). What mistake did this newbie make. The only thing i can think is i got the order of the lines into the prop valve backasswards(wasnt really clear from my reading).
Tim
Tim
