381 - 400 of 424 Posts
Discussion Starter #381
A little bit of tire hanging out from last weekend.
Same spot different view. It’s pretty steep but can’t really tell from the picture. Also to do this line you just about have to be on 40s or bigger. The break over is pretty hard.
so you ended up using the astro van steering gear from red neck with no drop pitman arm? I have the same issue with everything needed to be pushed forward,
1989 Jeep Cherokee
I must follow you on the instant social media application. Some guy on there had an identical problem this weekend and I think the same photo. I was kind of wondering where I learned about this random online person.
Discussion Starter #394 (Edited)
Yep that was me, it was on my Yukon. It’s my daily/tow pig. It’s all fixed now.
Nice, I finally got mine together now i'm just finding out what needs to be tweaked.
Looks like i'm gonna need to rotate my front Cs my caster is way off.
Discussion Starter #397
My Jeep wheeled awesome this past weekend. I did taco my driveshaft pretty good though.
The local shop that built it only charged $100 bill to retune it though.
I got my rig pretty much finished up ready to wheel., do have a little issue with the front drive shaft binding at full droop. are you using the 1350 u joints on your front drive shaft?
