UPDATE:
Front wheel bearing.
My 2002 2500HD Crew Cab - 2WD, 6.0 gas engine - 120K miles. Original owner.
I'm getting a low droning type noise. Loudest around 30mph, but getting noisier as time goes on. M&S Michelins getting worn, but seems to be more than just tire noise.
Rolling down the road at, shift into N - noise is the same. Driveshaft seems nice and tight.
First thought is front wheel bearings, jack up the tires and spin. Both sides seem fine, don't feel anything.
Rear wheels (locker diff), full floating axle, but seems fine.
Autozone has Timken OEM hubs for $250 each. At this point, ready to drop $500 in those to see if that is the issue, just checking on PBB to see if anyone has run into something similar.
Other than fluid changes, and a EGR at 80K, still running strong. Plugs and new speakers are on the to do list. :flipoff2:
Tom
Tom
