1 - 3 of 3 Posts
Hello . looking for information on drop pitman arms that fit my stock steering box ? I pulled the. stock arm off and counted 30 splines with 3 index slots .I did a search but the the information is vague.
blatant asshole
pulled steering box out and pitman arm off. it ended up being a" three flat" count shaft with 11 splines between the flats (33 spline)
You may be better off swapping a 2wd version into your truck
The fords im thinking of are 32 4k or 36 3k
Your truck is 32 4k 2wd or 33 3k 4wd
32 4k is the primary standard with 1007 options.
1 - 3 of 3 Posts
