Is the 1.3 sammi carbed long block the same as the 1.3 fuel injected block?
cajunsuzukispider said:the actual volume never changed, it's just one of those factory things they do. all the 8valve heads will fit all the 8valve blocks. If you don't believe me check the headgaskets at autozone for carbed 1.3 and TBI 1.6 from, like a 94 or something. it's the same. but, he's right about the fuel pump issue, make sure to have the right head for mechanical pump, or else spend 20 bucks on universal frame mount pump and wire it into the fuse box on a switched fuse. no problem. jd
