1 - 6 of 6 Posts
Battle Masher
Hey i just got a samurai without a motor and swaped in a used 1.3L with a stock carb. I got it all hooked up but when i fire it up it revs up to 5000+ and wont drop below. It seems like the throttle it pined but does the same without the throttle cable hooked up. Any help would be cool
Graeme
Battle Masher
Discussion Starter · #2 ·
anyone?
check the usual stuff - float stuck, etc. I'd try doing a search onm Izook or zuwharrie, there are probably a lot more threads over there on carb issues than there are here. You might also want to do a sirch on zuwharrie for 'fsm' and find a site where you can download it, then read through the carb/emissions sections.
missing vacuum lines and other issues can create a higher idle, but not in the 5000 rpm range.
rebuild the carb and check idle screw make sure nothing is getting stuck with throttle..
also i have had this happen and i let it rev up and it stayed up there for a bit but slowly came down to a normal idle . how long have you let it run?
Battle Masher
I just kill it right away
1 - 6 of 6 Posts
