1 - 15 of 15 Posts
I know that Jack and Dhondagod have used late model ferd rear springs on their 1/4 eliptic. I was just wondering what your impression of the spring rates was?? I have the perfect spot for a 1/4 eliptic spring pack on my 60 but was worried that the weight of a 60 would be too much for the stock ferd spring packs..
I know I could just add some more leaves to the stock spring pack but..
Any other suggestions?
Finish it?
Chris:flipoff2:
Fawker...
That is whatI am trying to do..
When do you want the cardboard box?
:flipoff2:
Whenever you get a chance..... After new years is fine too....
Update your thread with some pics if you get a chance... I want to see more of what you were talking about..
edit: of the frame
Chris:cool2:
i did coils in the rear of my 84 yota and used the old leafs for my 1/4 illiptics on my k5 i used the existing rear spring hanger and lengthed my wheelbase and ran a shckle with a heim on the axle....the full spring like proffitts cruiser guys run for example
Also, what is the length of the ford packs from the eye to the center pin?
Old Rock Doc
I use F350 Super Duty springs and I remove one leaf from the OEM pack. For your heavy assed rig, you might just leave that leaf in the pack. If no one else posts the length I can measure tonight because my memory fails me on that number.
Shhhhh.. you'll hurt Bob's feelings!!!
Thanks Jack..
Once Jack linked/coilovered the front the rig feels really balanced and working better then ever. The rear always felt great and one of the nicest working 1/4 's I've ever watched. The stock fj60 leafs when they were in the front always seemed to soft compared to the rear.
Discussion Starter · #10 ·
Linking the front is not in the cards right now. I just don't see the need or the benefit. Teh onyl reason I am linking the rear is to reduce the overhang issue. Why Bob a FJ60 if you are just going to drag shackles all over the place.
Looks like F350 springs with nothing removed shoudl work out nicely..
Hopefully they are short enough for easy fittment..
If not, I'll have to start looking around..
I have custom packs made by National (IIRC). Not sure of the spring rate but I could double check my paperwork. They work great on my YJ:cool2:
Discussion Starter · #15 ·
Bummer, I need it only an inch or two shorter than that to be effective.
These are the frenched in spring hangers that I was hoping to use for the 1/4
1 - 15 of 15 Posts
