1 - 9 of 9 Posts
Read Only
Ok, lets say you run a 1/4 elip setup. how come you need more than 2 more links? couldn't you just run a wishbone link (2 on crossmember to one on the pumpkin) with out probablem? don't the leaves act as a link themselves?
what about running a 2-link along the leaves above/below? Like if you made the springs SUA, then a link mounted 6" above them.
also when you cut leaves in half, does that change the spring rate? i mean, do you have to use a thicker than stock spring to acheive the same rate as the stock ones?
thanks
Paul
the axle side of the 1/4 ellip spring mounts with a shackle, so they do not work as spearate links. Additionally, the advantage to a full 4-link is using longer links than the springs would provide.
1/2 a spring pack = 1/2 the spring rate...one reason F250/350 packs are common for 1/4 ellipticals on light rigs.
hate to high jack this thread but i would like to know how many people actually drive their 1/4 vehicles in the street..........thats kinda the route that im planning on going.......ive heard of people driving them on the freeway but i was just curious
thanks
laurie
yea, i was kinda wondering the same thing, i want to do a 1/4 ellip setup on a daily driver, but im not shure weither or not to do it sence i will be driving it on the street almost every day
My friend runs one under his CJ7. bought it from Avalanche Engineering. 4 link setup and he drives it everyday to and from work. says he no problems at all. riding in it feels more stable than my leaf sprung Jeep also.
thanks
laurie
I drive mine all the time around town... coil over'd front, 1/4 elliptic rear, 32 bolt beadlocks, 39.5 boggers running 4psi, and full hydro steering.... I cruised at 70 mph this weekend for about 30 mins straight.. no problems..
1/4 elipticals are just another spring, so it will handle just as well as a linked up coil setup.
As mentioned you *could* use the leaf as a link but you are asking for wheel hop and limiting flex/wearing out springs faster.
also don't mount the leaf with a pivot at the frame, free fall flex is for ramp champs.
1 - 9 of 9 Posts
