1 - 7 of 7 Posts
Which autozone/advance pump do I need?
I have a t/c pump from a 1994 Grand Cherokee, bt it doesnt fit...(pulley doesnt line up with crank pulley, which is stock BTW).
I cant use the resovoir, witch is attached to the pump, will a psc style resovoir work?
Do I have the right pump, but wrong crank pulley?
Which belt do I need? Is it the stock tracker/kick ps belt, or other?
Thanks.....ROb
I have the bracket for the t/c pump, but need to know which one to get from Autozone. One that has a seperate resevoir.
I "think" a 4cyl Jeep (TJ, YJ, Cherokee??), but need the exact year/model so the guys head at the counter doesnt explode.
Thanks Rob
Thanks Rob
if there is a difference i would get the one from the larger vehicle , it probably has a bigger rotor ..
1 - 7 of 7 Posts
