1 - 20 of 20 Posts
I searched and saw all the old posts but I want to see if there is any updates on this.
I want to get setup with something bolt on so I can get going this weekend. Right now I am running a 72 FJ40 MC, 60 front, 14 bolt with disc conversion (74 3/4ton chevy calipers) in the rear. All lines are 3/16". I dont think the MC that I have now is going to do the job.
So is the best bolt on setup as far as the MC? Supras? What about a later fj40? I just want to get it up and going now and I will deal with hydro boost or whatever is needed later.
TIA
· Premium Member
I have the same set up as you, all most. D60 front,14 bolt with the same calipers as you but I kept the FJ60 master. I was going to go to a 1 ton chev truck master and boster but I have talked with a few guys that have done basicaly the same thing and say the FJ60 booster and master works fine. Wish I could tell you first hand but I have not driven mine yet. The FJ60 master and booster would be a easy swap just sorta expencive unless you could buy it form someone on here.
· Moderating Midget
I just went through this.
I ended up with a 1988 Toyota Supra M/C.
I got one for my FJ-40 and I loved it so much, I just put one on Wilbur yesterday. It is a BAD ASS setup.
Pep Boys sells it for $49.95 plus $15 core.
I think it is the way to go. Bolts right up, single res. and pushed some heavy juice.
My Pig stops on a DIME now!
Hey Nolen, talk to a cruiser novice. What do I need to make that work on my setup, or should I just continue the plan of moving all the junk over from the "donor"?
Ed
· Moderating Midget
Ed
There is a booster that needs a rebuild in the Cruiser. Sent it to the rebuilder and it will bolt up through the holes in the dash.
Eric, did you try Pep Boys?
Also, I run 1/2 ton discs in the front and 1/2 ton drums in the rear (6 on 5.5 outers)
Discussion Starter · #12 ·
Unfortunetly we dont have pepboys here in these parts and their website isnt worth a damn.
I will run to Schucks or autozone and hopefully they will have one for a decent price and a resivour.
Thanks
Discussion Starter · #15 ·
Nolen do you think even though you are running 1/2 ton brakes that the supra MC will still push enough fluid for 1 ton brakes?
High5 what mods did you have to do to fit that setup in? What parts would I need to get?
Nobody around here sells a supra MC with the resivoir for under $180:mad:
· Moderating Midget
Should not make much of a difference!
Discussion Starter · #18 ·
I ended up getting a junk yard supra MC for $20 so that will more then cover the $35 core and I got a resivour with it :D
I put it on and bled it out. Right when I was going for a test run I found out I didnt have the front lines where they need to be and one got clipped. :rolleyes: Still was able to drive it around a bit. Feels good!
Thanks for the help guys, Nolen. I will be sure to let you know if it dosnet work out :flipoff2:
i ran 1/2 ton disc's at all 4 corners on my old setup with my stock jeep master and worked great. when i went to 1ton stuff it would not stop it. that is when i switched to the hydroboost setup.
well my setup will be a bit different because i am running my brake master and pedal in the clutch pedal position on my rig. i had to do this because of how i mounted the jeep tilt column in it.. anyway i had to drill two holes and cut the plunger down and attach the threaded end of the cruiser master onto the GM's plunger. i did not thread it i ust cut to fit and welded it on. the hard part was i had to cut away some of the firewall support and then when i drilled the outside hole it ended up hitting right where the bracket that the pedals are hung from attached to the firewall. i had to do some work to get it in there but it wasn't too bad. i don't know if this would be as much of a problem if it was hund where the brake master normally is hung. you do not have to have a pump designed for a hydro-boost (i do) you can just use a t-fitting in one of the lines. i can't remember if it is two pressures or two returns on th hydro-boost setup. my pump is for hydroboost so it has 3 fittings on the pump. like i said earlier they WORK!! i really like them.
1 - 20 of 20 Posts
