1 - 4 of 4 Posts
Alright, this is sketchy tech, but you guys can help. I figure the 10 bolt guys can help out/be helped, anyways.
So my buddy's got a 91 Z28 Camaro 10 bolt rear. He blew out the R&P, and took it on himself to replace it. Well got the ring and pinion replaced all back together, and everything is fine except for one thing. There is about 1/4" of in and out play on one of the axles. The c-clips are in. Why is it doing this? How should he fix it? I told him it was time for a 9", that was my advice. Thanks for your help, and for all you flamers (I know its coming) :flipoff2:
Sounds like maybe he left out a thrust washer behind a side gear. There should be a small amount of endplay, but 1/4" is too much. Look for a thin metal washer about 2.5" in diameter where he was working.
And why would anyone flame you for having a :rainbow: friend with a :rainbow: 10 bolt axle? :confused:
well, this is PBB, right? just wouldn't be right without it :D
Hey man, everyone has :rainbow: friends, it's the 00's
If it's not the washer left out, then something (c-clip or axle shaft) is WTF out (worn out)
1 - 4 of 4 Posts
