1 - 20 of 35 Posts
What vechiles did GM put 10 botl 8 lug axles on, or was just Dana 44s that came with 8lug.
Thanks
Ross
3/4 ton, if it was 3/4 ton it had 8 lug. 1 ton would have been a D60. They put them in trucks and Suburbans. Not sure if they went in anything else.
im guessing 80-87 3/4 trucks had them. maybe some late 70's. some 3/4 tons are 6 lug, though.
Krawwler said:
73-87 3/4 ton pu/sub.s & old body style 3/4 tons thru 1991
8 Lug D44 73-78 (a few in 79 and 80)
8 Lug 10 bolt 76 (very few)-91
I have a 78 4x43/4 ton w/8 lug 10 bolt corprate front & 14 bolt FF rear & also a 86 chevy 3/4 ton w/8 lug 10 bolt chevy corprate front end & a semi floter14 bolt rear end just to let you no
Lincolnloc said:
HMMM, I call BS on a 3/4 ton 10 bolt Rear
like i said, ive only seen 14 bolt rear (semi-float and full). i guess i should have wrote it less confusing.
What i meant: on 3,4 tons, i have seen mostly d44 fronts w/ 8 lugs. i have seen 10 bolt font with 8 lug as well.
so yes, you are correct to call the bs
BROKENGMC said:
NEWBIE.I HAVE A 89 GMC 1 TON WITH A SINGLE TIRE AXLE.I'M INTERESTED IN CHANGING THE BRAKE TO DISC FROM DRUM.I NEED TO KNOW HOW TO TELL IF I HAVE A DANA 70 OR A CORP. AXLE.:eek:
Won't matter - they use the same brakes.
It's pretty fawkin easy to tell, man. Just do some re. It will probably take a total of 20 seconds for you to find a PICTURE of a 14FF or a D70. Then you can go out and look at it.
Or, you can take a pic, and post it, and we can tell you how dumb you are, but you will still get an answer out of us. :D :D
Or I can save you the trouble, and just tell you. It's a 14FF :flipoff2:
1 - 20 of 35 Posts
