What part of that do you not understand?:shaking:No! Different carriers. Do some reseach for yourself for once because if you did you would already know that there are 3 differnt series for the car 12 bolt and that there is 2 for the truck.
That's what you measure dumbass. How much more specific to I have to be.Since I know that you will ask, the way you figure out what series you have is by measuring the distance from the bearing shoulder to the ring gear flange.
That's what it should measure.if you have the r&p and carrier just measure (read above)
12 bolt truck
series 3 should measure .895"
series 4 should measure 1.145"
No. I don't know everything and never will. hence the reason why Pirate even exists. I do searches on it and google all the time. you just need to do more research. I found all of that when I was going to try to beef up my pos 12 bolt. Took no more than ten minutes to find that info too! You just want the rest of us to do all the work for you.Not everyone starts out knowing everything there is to know. You must be one of the lucky ones I guess.
And i was specific as to what you needed to measure. just thought that you would have already known that you needed to stand the carrier on the ground with the r & p facing up since it is pretty damn obvious:shaking:Since I know that you will ask, the way you figure out what series you have is by measuring the distance from the bearing shoulder to the ring gear flange.
I am not trying to act that way but if you have seen or been involved with any of his other threads you would understand. I gave himm all the info that he needed then he acts like I was just giving him shit. Which I might be to an extent since he always wants everybody to do all the work for him. I know that I don't know shit compared to some of the guys here and I have the up most respect for them and there time.76POS
You have some big words for being a noob on here. Don't just show up on pirate and think you are King Shit here.
76POS
They can be found in a 14 bolt full floater:lmao:![]()
just wondering.. who makes strongest gears for 12 bolt?
Just messing with ya
But seriously time to scrap the tiny 12 bolt and go 1 ton.
