1 - 8 of 8 Posts
Please see my website for products, I try and list more each day.
www.12voltguy.com
530_534_1507 [email protected]
Paypay [email protected]
LOCATED in OROVILLE,CA 80 miles NORTH of SACRAMENTO
all my adds on here, this will help out this section, so I only have 1 add to bump :)
New Plastic Colored In_cab Winch Controll Panels
http://www.pirate4x4.com/forum/showthread.php?t=284446
In_cab Winch Controler Panel
http://www.pirate4x4.com/forum/showthread.php?t=278816
EMERGENCY STOP KILL BUTTON, Dash Mount, ant interest?
http://www.pirate4x4.com/forum/showthread.php?t=281711
E_STOP Push Button $19.99 ONLY 5
http://www.pirate4x4.com/forum/showthread.php?t=283095
Toyota Electric Locker Switch Panels_Ignition/Start Panels
http://www.pirate4x4.com/forum/showthread.php?t=275062
RED GAURDED Toggle switches with LED built in 30Amp HIGH GRADE
http://www.pirate4x4.com/forum/showthread.php?t=279618
12volt parts led indicator lights, switch panels fuse blocks red gaurded switches
http://www.pirate4x4.com/forum/showthread.php?t=274814
Rocker Switches
http://www.pirate4x4.com/forum/showthread.php?t=275971
Toggle switchs with LED Light in Tip of Brushed Aluminum Handle
http://www.pirate4x4.com/forum/showthread.php?t=275241
6 circut fuse block
http://www.pirate4x4.com/forum/showthread.php?t=275283
texaspyro21 said:
If i sent you a pic of what all i needed, do you think you could put the package together? It would include 2 relays, wiring and a couple of switches.
Yes Sir!
send me all info, & if I don't list an item, ask I may have it, or may be able to get it, at least I WILL TRY:)
I'm working on a self contained box with 4-6 switches, Starter button leds & relays,
12vdc fused input in
ground
outputs from all switches
dual battery setup kits....
200 amp solenoid, marine A - B - A+B - off switch, basic idiot proof directions... ;)
I have not found a resale source for these items.
I have a 200amp rely/solinoid/isolater for my rig, but my batterys are F & R so I won't be running an a-b-A+B switch
1 - 8 of 8 Posts
