1 - 6 of 6 Posts
How much can a 14bff be turned up toward the transfer case ,before the pinion bearings starve for oil? Is the slinger big enough for the pickup of oil?
texas so i assume 12-18" lift.
they can go pretty high but at the same time you need remember that your ujoints will be out of alignment and will vibrate.
i would say over fill it, but if your seals are old they will spew oil out and it drain itself to the bottom of the tubes level.
Well, I'm from louisiana, just work in texas.So i think its 20-25" of lift:laughing: It's not that high ,the previous owner installed it. In fact, it looks like you could turn it back down some but i just wanted to see so i wouldnt have to mess with it.
1 - 6 of 6 Posts
