1 - 19 of 19 Posts
Super Moderator
Bolted up the front 1410 shaft on Shaffers rig last night, and it binds bad at droop. Looks like there is quite a bit of meat on the yokes, but jeez it looks like I'm going to have to take a lot off to keep from binding at full drop. How much meat do you think is safe to grind without compromising strength?
for you i wouldnt grind any i would limit droop as fb wont be able to pick that sht out of those holes this year hehehehe :flipoff2: remember if ya touch the rig you DQd :flipoff2: :flipoff2:
Ok, this may sound like a dumb question, but why all of a sudden is everyone runnin 1410s?? I didnt see any 1350s breaking, but I only made it to a few comps so I missed alot of action, just wondering if the 1350s were breaking that often:confused:
i am switching because the 1410's allow more travel before binding. atleast that is what a chart i saw said. the rig i am building is close to binding when at rest so i know i need some more travel.
Have jess make you up a double CV . Then you can drop it to china and not worry about it.
lance a little cleaning on the casting is cool- or a limit strap even- a little being 1/32 or so- or we could go yoda and acheive almost the same stout-ness and 41 degree's -Jess
i ground alot off mine and they are holding up. it's dark out and my rig is on the trailer. i'll get pics in the morning if ya need them
Nice erik - we fully expect pic's in the am huh! I put mine thru a little stump/tree expulsion this weekend bent the rear bracket on the frame holing the strap and distroyed the strap ends- the tree finally gave up now its a nice place for a garden - hunny doo's converted into fun! :D - Jesse
Super Moderator
Discussion Starter #11
We have a limiting strap on it, but at full droop it binds. We need the droop. The shaft is at approximately 33* at full droop. I grinded the piss out of the yoke and it clears now. I don't think it will be a problem now. Jess, you can do a Yota yoke on the Atlas? :confused:
i have now run mine ground like you see on 10 hammer trails and 2 days at pismo. i will be pulling my whole front end apart this week to inspect every thing and i will have the yoke magnafluxed. visual inspection looks good but we will see how it looks after proper inspection.
i run 1410 on the pinions because they withstand being smashed on rocks better with out the ubotls flying off.
Makes sence too me:cool: Im still running puny 1310s, but have yet to break one(I must not be "gettin it":D) but was planning on stepping up to 1350s. So does 1350 at the t-case and 1410 at the pinion sound like a good idea? I still run my rig on the road every once in a while so Im not sure the 1410 cv would be good for me. FYI my drivetrain is stock 4.0,AX-15(not for much longer),D300, and 35spline 60s.
Let us know the results of that magnaflux camo.
Thanks;)
i used to run 1310's in the jeep and when i got the atlas i stepped up to 1350's to match my 14bolt and atlas yokes however the 1310 stayed on the front d60 yoke. i have broken alot of stuff on my rig (front d44 u-joints, front d60 lockout, front dana60 stubs, drive shafts, eng mounts, transmision housing, etc, etc and i never broke a 1310 u-joint that was not a result of either axle wrap or a failed pinion yoke. never. i run 42's with a vortec 350 and i am not scared to get it. i don't know weather i have been lucky or if they really don't break that much. anyway i am going to 1410's with the new rig just because. the 1350's don't allow as much travel and i am close to binding as it is. with your setup i see no reason not to stick with 1310's. just my op.
1 - 19 of 19 Posts
