1 - 7 of 7 Posts
IUm getting ready to bolt up the newly shaved 14FF to my J10. I know the old Ubolts will not be wide enough, so won't I need a wider plate for the top of the springs too? Im thinking that I won't be able to use the exsisting ones. And which ones and where can I get some for finishing up this projest? Thanks, Dennis
why will the old bolt not be wide enough??? did you change tubes also??? I think you should always change u-bolts but just pattern the new ones off the old ones...I also had some 5/8 ones made up for my 14 bolt...
Because he probably did not have a 14 Bolt in place before:rolleyes: I am sure a J10 did not come with a 14 bolt originally.
· Premium Member
Just go to a junkyard, find a decent 3/4-1 ton Chevy Van, 2wd truck, etc., and get the plates and u-bolts off there. Older Chevy 1-ton trucks had round 5/8" U-bolts and something like 1/4" thick spring plates, very beef. It will cost like $5 total.
1 - 7 of 7 Posts
