1 - 7 of 7 Posts
what backspacing will cause a 15" rim to fit over the 14 bolt ff brakes? i have seen one wheel that 4wheel parts sell that has 2.5" backspacing, will that clear?
I'm not sure, But i believe they only go on the 11" brake full floaters??
my 15" wheels have 4" back spacing I am also running disc brakes to:flipoff2:
15" rims pretty much all fit over ff14b drums. I run both US Wheel series 75 wagonwheels that have 4.25" bs and eaton HD steels that have 2.5" of bs.
j
Pretty much all the 15 in. rims will fit but when you get into the 4in. + BS on the rims if you convert to disc brakes you might have to break out the grinder for the calipers....
Steel wheels all fit AFAIK. On the small drums, all aluminums will fit. On the large drums, I dunno, some aluminums may not fit... Rear disks may be a problem depending on the brackets and donor...
1 - 7 of 7 Posts
