1 - 20 of 64 Posts
1947 CJ-2A #2012 - year of the Flatfender.
Flat Fender time!
I picked up this little gem the other night, I'm super excited.
It's loaded with lots of great parts, but still needs loads of work too.
It's got, 289 V8 (intake off, sitting in the rain since 1993) C4, overdrive, disc brake dana 28 front, 11 inch rear drums, the wheel wells are carved over for more seat room, power steering, tilt wheel, taller 3a windshield, swing pedals and I'm sure more.
It's got some cool homemade doors on it too, I'll shelf those.
Yes, it's got some headlights from a Pontiac put on, it's done nice, but not my style, I have a different grill to put on it. It also has a hell of a front shackle reversal with billboard for a front bumper, I dislike it, I'll swap it back to normal.
Plans are 32-33 inch tires and just something to put around in.
I want something that has 1970's technology/built time.
I've got about 10 hours I forsee in presure washing before I can start to pull the motor and swap in a 302 i picked up from a friend. I'd rather have a 289, but this one looks pretty trashed.
I'd tell ya what I paid for it with almost no rust, but you people would hate me.
Discussion Starter #2
Options list!
Discussion Starter #5
So what I do about that dash?
It looks so out of place and all hangy down too low.
I'm sure it's because of the 3A glass, but how can I move it and still keep the vent and access to the wipers?
Are you sure you want to ditch those headlights ?? :D
Seems pretty straight.
Does it have the original dash under that thing ??
Original dash is not much better than that one. It would normally be flat though. You probably fit in a flatfender about as bad as I do. I'm going to mount the seats as far back as possible including some fenderwell trimming. I also thought about moving the firewall forward a couple inches to get more leg room in mine.
Discussion Starter #8
:laughing: I'm sure I want them gone, while they have grown on me, If I saw something like that on the trail, I would laugh in my own face.
No dash behind it, well, that I felt.
Like I tell all the girls, I can fit anywhere, it just takes some time.
Na, I fit like crap in a flat fender, I can only drive Power Sterring ones.
This one being an auto (not sure if I'll keep that, depends if it works) should be easier to fit in.
Can I vote on the finger buster steering wheel? The grill is awasome, but I would still laugh at it, asif I ever hit the trail:shaking:
Discussion Starter #11 (Edited)
HAHA, those Jeepney's had the same deal... how sad.
I might splash some paint on it and see how funny it looks.
I gutted the inside to the dash last night, loads of carpet and glue that were cleaned.
Noticed the other day the tranny does not have park, not sure if the pawl is busted, t-case shifters not all the way or tranny linkage is funny.
At least with it washed I can look at that in the next few days.
If I have to pull the motor, I might as well take the tranny with it and do a quick rebuild. It's been a while since I went though a C4, they were easy from what I remember.
Speaking of, I notcied when I was cleaning the tranny has the very early cruise-o-matic shifter, the one where you have the 2 dots for drive so it starts in 2nd gear on one of the dots.
Discussion Starter #12
Progress.
About 2-3 hours pressure washing it, interior removed (with carpeting, barf), motor stripped ready to be pulled.
This thing is covered in some type brush on liner or rust proofer, or tar. I dunno but it's kicking my ass removing all of it. I'm going to try and get some paint stripper and if that takes it off.
I'm going to redo one of the motor mounts as I think it looks like crap.
Also with the grill off I see where he pushed the grill forward about an inch to fit the 289, It's really easy the way he did it, I'm just going to clean it up and put some nicer looking welds on it.
I also noticed that the 289 is one of the pre 65's, it uses a 5 bolt bell housing. I do have another c4, so I'm going to rob that bell housing off it as the 302 I have for it is the more common 6 bolt. I forget if these two just swap over or what flex plates need to be changed, but looks like I might have to pull the motor twice if I'm wrong...
The tranny in it is still unknown shape, I have 2 c4's in my parts pile, one I know is crap, the other no idea. This one in the flat fender still has red fluid so I'm going to give it a try.
Discussion Starter #13 (Edited)
Oh, where the hell can I stick an Optima battery in here?
Can I hog out the fender a little more?
It's the battery I have so I want to use it.
Oh, you can tell by the heater hoses but it has a freaking heater in it too, awesome, I hope it still works.
Who sais the battery needs to be in the engine compartment? On my last truck it was under the bed with A door to get to it. Jump starts were allitle wierd.
2nd to last cross member is where mine's hiding (for now)
It gives it a little weight in the back to offset the V8 in the front.
Could you post some pictures of it underneath? Curious to see the driveshafts with the auto trans stuffed in it thanks.
Discussion Starter #16
Small updates with way too much time...
Engine bay and frame cleaned and an old 302 stuffed in it
Good job !
Are you gonna cut the hood or change the air cleaner ?
1 - 20 of 64 Posts
