81 - 100 of 329 Posts
Discussion Starter #81 (Edited)
You should stick a cigarette/12V power port under the drain plug....like you have to unscrew the drain plug to use the power port :smokin:
Good idea :grinpimp:
These cables are so freakin big, they're not making it easy :mr-t:
Discussion Starter #83
I think I'm going to go back to my original plan of making a console. I'll see if I can make it look old.
This oil pan is a little too small for this shifter. I'll save them for another project some other day.
Oh well,.. The oil
Pan was a great idea even though it didn't play out as well in reality! Like you said another project! Love the ingenuity.
Discussion Starter #86
Thanks guys.
I went back to the console I started with and added a flange and got the curve in it to match the dash, as Tom (49willys_mogon) suggested. Not as much character as the old oil pans but works well.
I might still play around with the green pan :shaking::D
Lazze and Covell make it look so easy..eh? :)
That's cheating!! Rolled a bunch of floor panels for my Edsel the other day on a manual roller, really hard to get straight lines without a helper, needed a monkey to crank while I steered, oh well, it'll be under carpet anyways!!
Whats the plan for headlights? Looking for some short depth style since the wider radiator intrudes on the stock buckets....
Great build so far!!!
Discussion Starter #93
Haha...ya it's a pain trying to do it without a helper. I'm certainly not spending 5g's on a bead roller, just need to find someone with one. Maybe I'll take one of his classes and bring all my project pieces with me...lol
Discussion Starter #94
I'm using stock lights and buckets trimmed up a bit. I'll take some pics when I get back into town.
Discussion Starter #96
I only had to trim one for the a/c line.
Thanks! Mine is right at 26 if I recall.. should slip in. I am running an old style water pump so your late model stuff is a bit longer, should give me some more wiggle room.
