1 - 8 of 8 Posts
I'm a new member here (yes I posted in the introduction thread). This build up is mainly for my own records, I will be putting up pictures of what needs to be fixed and after they are done. Enjoy all the crazy shit I find!
1972 CJ5
AMC 304 (swapped after original jumped time)
M/C 2100
T-18 and D20 from FSJ? The transfer case has a U shift pattern.
D30, D44
SOA
I picked this up for $1000 from my sister when she needed some cash. Her boyfriend was a backyard mechanic that also had a bad habit, so I'm not surprised to see some of the "issues" with this jeep. As far as I know she got the Jeep for $1500 and her boyfriend worked on it a little. I know for sure that he did the engine swap when it threw the timing chain, and his re-wire was far from pretty/functional. It was used by them as a hunting/off road jeep, never driven on the street as they live out in the sticks. The first thing I did when I got it home was start in on the wiring in the engine bay. After I got it all situated and working properly I started to go over it to get familiar with it and that brings me here.
The Good:
Everything seems to work as it should. The motor sounds healthy, but the carb needs a rebuild. Four wheel drive works, all lights work, and most of the gauges work (no fuel sending unit hooked up). The brakes function as far as I can tell, although I havent driven it any great distance, just on and off the trailer and a few hundred feet. It has power steering.
The Bad:
Its got some rust, needs a new battery tray, and still has some wiring that needs to be replaced.
Because who needs a new cable anyway?
I guess a Jeep technically is a carriage, but come on.
They gusseted the other side, why not the rear?
Welding rod, not just for welding!
Missing body mounts
This shock mount needs some serious bracing/re doing.
I dont even know what to say on this one.
Discussion Starter #2
Bent front drive line. Yes, that is a fuel hose.
This body mount that doesnt even attach to the body.
Under seat gas tank, lets just duct tape over the hole!
The p/o didnt have any silicone when installing the under seat tank, so he used boogers instead.
Trans tunnel looks like it went to some dicey plastic surgeon in Mexico and got the $19 special.
I think the windshield had a habit of jumping off. This should hold it.
I dont plan to make some insane rock crawler, I just want a decent rig that I can take out moderate trails and not worry about brush scratches and dents and broken parts. Ive been to the hammers a few times and always take quads, I'd like to take something a little more comfortable next time I go, my knees were killing me last year! For now I will be keeping the drive train the way it is, I dont plan on running larger than 33's and there isnt much around here that technical, mainly forest roads and some trails off of those roads. I will keep updating as I find more things wrong/ fix those things.
Discussion Starter #5
Jeez I got a chuckle out of that.. The carriage bolt takes the cake..
Ive been trying to laugh things like that off, but the more I find the harder it gets. I can see being on the trial and needing a bolt, but I know thats not the case, and the damn thing isnt enough long enough to thread through the entire nut :mad3:
I did a little work on the interior today. The seats it came with were disgusting. I ripped those out and the half assed angle iron that was holding them and fabbed a new mounting bar out of 1-1/2" square tube. The seats are out of a Ramcharger and are a little beat up, but some seat covers will do the trick for now. Also added an ammo can that I will be making into a center console to house the cb, stereo, and other junk, and welded some VW aviation cylinders to the console frame for cupholders.
Also got started on a trans tunnel cover to close the hole up until I can get a new tunnel.
The dash was cut up pretty bad, and I had a galvanized sheet laying around so I cut out a blank.
I dont know if you can tell in the last picture, but thats a grant wheel. Welded to the grant adapter. :barf:
1 - 8 of 8 Posts
