I am going to do a shit load of plating to the frame. I got some RuffStuff 12" shock towers I had planned to use in another build that I could use on this truck. Bit overkill for just plain shocks and there is a drama with the steering column shaft but I may use them anyways.Hey Ian,
Recently I tore my ford shock towers right off the frame on my frontier. The towers and the welds didn't give way...the frame did. Might consider some gussets to the weld points to spread the load out. Just a thought. I shitcanned those in favor of some proper hoops this past summer.
I could have set this truck up with a 3-link front and 4-link rear. I have housings all set up for that and ready to rock. Just didn't want the expense and this truck will not need the flex. It only will have about a 55:1 crawl ratio so it is just not suited to serious rock duty. It will flex decent with the leaves though, enough for what I have in mind with this build. Got a RuffStuff traction bar set up awhile back to use in the build.
Only thing I really need to get or work out at this time is steering box. I have a 160 Patrol box in LHD I can use but not sure I want to. It is a little bit of a funky box. I am thinking 80 or 100 series Cruiser box.
Cheers
