Gents,
I have a problem. I replaced my lower tracbar mounting bolt with the ingalls kit and that has been super. When I did that I replace the bushings with a set of Moog problem solver urethane bushings. Everything was fine for a couple of hundred miles and the popping started again and it was at the frame mount. I have a drop bracket that came with the lift system. I can see the bar moving around the bushing when the wheel is turned. What are your suggestions? Do I need an adjustable tracbar, heim joints, what? Thanks.
