1 - 2 of 2 Posts
i was wondering if i could just cut the belt running from the engine to the air supply pump without running into any problems? i dont need to go thru emissionsn anymore, so technically i dont need the have the air supply pump hooked up right? the bearings in the pump are going bad and making a bad noise.
thanks
brandon
Yea, cutting the belt will be fine. Know that eventually though you are gonna want to take the hoses, pump, and other shit from the heads off or the gasses will be hot enough to burn through and cause leaks.
It isn't hard to take all of it off though. Just trace the hoses and cap them. The biggest problem is in the back of the heads...the piece connecting them needs to be replaced with block off plates.
HTH Phil
1 - 2 of 2 Posts
