1 - 20 of 42 Posts
Now with price........ $9999
318V8 4bbl. Carb (1976)
aluminum intake
MSD Ignition
K&N Filter 14" Diameter
performance built Rochester Quadrajet
engine will need a freeze plug replaced on the driver side (easy fix)
truck NP435 4 speed granny low first (gonna need synchros eventually, grinds going into 3rd)
Dana 300 transfer case (single stick, stock gearing)
2.5" flowmaster exhaust inside framerail full length.
dual Optima red top batteries, with Perko switch disconnect
Power steering (new gearbox)
Power 4 wheel disc brakes
Dana 44 front axle, 5.13 gears chromoly outer axles (Warn)
factory cut and replined inner axles
Ox locker (cable operated)
Warn premium hubs
all new or rebuilt parts.
Dana 60 rear axle, 5.13 gears
35 spline axles, chromoly spool (moser), Teraflex full floater hub conversion (comes with a spare set of hubs)
35 spline drive flanges (NWfab)
1/2 ton Ford rotors front and rear
same calipers front and rear (GM Truck)
2.5" Rancho spring over lift
M.O.R.E front shackle reversal
2" body lift
Custom SMF front bumper with Warn HS9500I Winch
Custom SMF rear bumper with swing out tire carrier w/ Hilift mount
Custom SMF rocker gaurds with DOM tube step
SMF bumpers are all TIG welded and powder coated black, bumpers have built in clevis ring mounts, rear has a built in hitch as well.
New white paint outside, inside body is spray lined front to back.
Hella H4 headlight conversion, Clear/Red LED Tailights
Full length soft top and full soft doors
Leather bucket seats front, fold and tumble rear seat (not mounted)
Pioneer AMFMCD player, Pioneer dash speakers
(5) new BFG Krawler Blue DOT tires 37x12.5x17 and black steel rock crawler "soft 8" wheels
plus spares.... new Aero 26 gal steel tank, spare uncut front axles (std and chromolly), shackles, Hilift jack, some offroad lights (not mounted), soft half doors, half cab bulkhead only, set of 5 point harnesses,... maybe a few other parts
The following parts are available seperately,
Full length hardtop (spice) and full hard doors (brown) for an additional $1200 will not sell until Jeep sells
Also a NV4500 5 speed Dodge version, with an Advance Adapters SB Chevy adapter bellhousing, hydraulic clutch kit, CenterForce 1 clutch and pressure plate, Throwout bearing, Chevy input shaft and bearing retainer. Trans is a zero mile rebuild with the 5th gear fix and has the x-fer adapter for a D300, 29 spline output/input.
$2000 obo, will not sell until Jeep does.
I am firm on the price of $9999 for the Jeep
This is a very nicely built Scrambler that is clean.
or buy it all as a package deal for $12999....
Loacted in Blue Springs Mo. can email pictures upon request.
Discussion Starter · #12 ·
If I remember right it was either a 1976 or a 1978. The gears are 5.13's, cant beleive I forgot to add that....oops. I will get you some pictures later today. It had the engine swapped in before I got it and whoever did it did a very nice job with bolt in mounts and squared correctly.
1 - 20 of 42 Posts
