1 - 20 of 34 Posts
Well here is a condensed version of my build up.
Chevy TBI V8
SM420 Trans
Dana 300
Dana 60 front
14 Bolt rear
40 Iroks
Full Hydro
As it started
1st build
Where I'm at currently
My ram from POS should be here early next week. All that's left:
plumb from brakes
regear front and rear
Install orbital valve and associated hydraulic lines
and a ton of little, but time consuming stuff
I should have it going by mid to late October.
I bought this paint at Home Depot, it's extremely flat, great for touching up scratches. I was a little leary about rattle can piant for the body but it looks really good! Color is Deep Forest Green 1919
In this pic it looks like your coil to frame clearance is pretty close. Have you cycled the suspension to check for rubbage? It could just be the camera angle though playing tricks with me.
Yeah it looks deceiving, the lower shock mount tabs or as far out on the axel as they can go (without mounting them to the C) and the upper shock mounts are parallel with the frame. I did cycle the suspension and they have plenty of room. Now the ram and steering rods is what I'm concerned with. Those Ballistaic Fab hy steer arms are beefy but they posistion the steering rods awfully high.
Nose to grindstone
I like the steering arms they are great but why run 2 hole super steering arms on both sides?
Discussion Starter · #17 ·
Couple Questions...
What are your link spec's (length, material, joints)?
also
What are your coilover spec's (length, spring rate, valving, etc.)?
Thanks in advance!
Lower links are 1.5" .250 wall sleaved with 1.75" .120 wall DOM. Uppers are 1.5" .250 wall only
Coilovers are 14" Bilstein rockcrawlers front and rear with the digressive valving and King coils. The rears spring are both 14" 250 lbs on top and 300 on bottom. The fronts are 14" 300 lbs on top 350 on bottom. I'll get the lengths and heim size for you later,
Discussion Starter · #20 ·
Well I managed to get the hydro ram from P.O.S mounted today. Let me tell you this thing is a monster! Trying to get everything mocked up for tack welds is a mutha trucker! It involved tie down straps, 4 hands and alot of cursing. I think I got it where I want it finally. Still need to add some tube pieces in the middle to add some strength. If you see anything wrong with positioning please say so and why.
1 - 20 of 34 Posts
