1 - 13 of 13 Posts
I have a Wagooneer with 360 automatic(bad) i wanted to know what kind of axles are under it? thanks for anyone that help
they are all junk,
send all wagoneers to me
wagoneers are junk
you dont want wagoneer parts
send wagoneers and wagoneer parts to me!
peace,
Dave
Discussion Starter #6
thanks cue ball for the help do u know if they were a heavy duty axle and what gearing comes in the stock jeep axles
They're about as strong as any D44 or M20... probably handling 35-37" tires, possibly a smidge larger with delicate care.
Stock gearing in 80's wagoneers is pitiful, most likely 3.31's or 2.73's.
Is the engine good? I need a 360 for my 82 cherokee. If it's not running, what do you think is wrong? It's a pretty common swap to put waggy axles under smaller jeeps but when I was trying to part out the cherokee, I couldn't even give them away so now I need to put a motor in it so I can get my money back out of it.
FSJ AMC20 has one piece axle shafts and thicker axle tubes, compared to the CJ amc 20 axle, larger r&p than a 44, I have just placed one under my YJ, and all that I have read the FSJ AMC20 is as strong or stronger than a D44.
1982 Waggy front D44 I think will have the vacuum disco on the diff housing though.
IIRC, the only two years for the Discofabulous D44 were 83 and 84
not that it's an altogether terrible thing, anyway.
1 - 13 of 13 Posts
