1 - 15 of 15 Posts
Ok my setup now is a 318 727 trans and np208 tcase
the tcase will not go in 4lo
the is a guy local with a 727 trans and np203 tcase out of a 88 ramcharger would it be a direct swap to my truck.
Double check what transfer case is in the '88. It should be a NP241, not a NP203. The NP203 was only used from '75-'79, unless someone stupidly swapped it. But no, a NP203 would not be a bolt in due to the driveshafts and having to lock the CAD. The NP241 would bolt in place of the NP208, and would be a slight upgrade but I would adjust the shifter linkage on the NP208 first as it is a common cause of your issue.
Yeah my np208 will not go into N or 4lo the shifter is adjusted and the fluid is good I think it is the range fork.
The only problem is I can not find any good replacement parts to redo my 208 as far as range fork chain and seals. I know it is not to hard to replace the range fork.
If you can use a computer, you should have no trouble finding seals. The chain should also not be an issue. The fork might be a problem considering the NP208 has been out of production since 1987. If the drivetrain shops can't help, used may be the only answer. For all the trouble, I'd just find a good used NP241.
If we knew where you lived, it would help. If you were near me, I'd give you the builder 208 in my garage.
Travis..
A Dodge NP205, NP208 and NP241 will bolt up to your '84s transmission. The NP205 would require driveshaft mods, the NP241 is a bolt in swap. An NP203 looks nothing like any of the other transfer cases with a large cast steel housing and a fairly large aluminum housing in the front for the low range box. You can easily Google pics of any transfer case you desire for comparison.
1 - 15 of 15 Posts
