well im tired of working on it but heres the skinny
1984 toyota 4runner
-22r dual row timing chain... completely rebuilt new block/heads/all internals only thing not new is valve-cover (receipts in hand built by napa speed and engineering in napa ca last yr the engine ran fine but but bunch of extra money so had it all re done. silly i know
-lce engineering smog legal header with air injection tube adapters all hooked up over $400
-turbo 22re clutch installed
5spd manual
-v6 brake booster and brakes up front all break front and rear work and bled properly
-new alt
-new starter
-new fuel pump
-carb is oem and works well
-3in lift no blocks
good 31in at tires
-brand new complete set of black gloss procomp wheels with 1in spacers all corners
-trail gear front bumper almost $400
-front axel rebuilt everything except the gears in dif, and axel shafts done from marlin crawler
-all power with sunroof working rear window
-magnaflow carb legal hi flow cat with heat sensor from daves off road
-all new belts
-converted ac system and works well
super winch talon i series 9500 with synthetic rope cost over $900
i have so many recipts for this thing its not even funny... it runs and drives just needs exhaust welded up past header has clean cali title im active duty military and was gonna title in idaho. super easy and ill even do it it you wanna do an idaho title to get out of smog etc...
i paid 3700$ and have well over 7k invested but i wont get 7k and thats life. im in suisun city ca. i cant figure out pictures here so pm me for my cell. i have nothing to hide, you can drive it around and test everything out. im just tired of working on it...
i kept all smog items in place just in case too. so its all currently hooked up and working.
black body, black wheels, non tinted windows give me a pm and make me offer. will not part out!!!
will sell separately:
-winch
-trail gear bumper
-steering bump tab re enforcement tabs un opened in bad
-front axle gussets brand new un used
-rock sliders and brackets from either trail gear, marlin crawler, or lce not sure dont care unopend still in bag
1984 toyota 4runner
5spd manual
-new alt
-new starter
-new fuel pump
-3in lift no blocks
good 31in at tires
-all new belts
-winch
-trail gear bumper
