1985 Chevy CUCV M1028 with 76,112 original miles. Very clean, the truck spent most of its life in Florida and Alabama. The picture of the truck on the RTI ramp does not reflect its current condition, it is only included to demonstrate the truck’s capabilities. You can look up my instagram (@jony_bakes) for more detailed pictures of the build. Asking $20K OBO, also willing to consider trades or trades plus cash.
Tires/Wheels: 40x13.5 Pro Comp Xtreme MT2s on Raceline 17x9.5 Monster beadlocks with the aluminum ring powder coated black.
Bed: M101 trailer bed swap. The bed was stripped down, repainted, bedlined with Raptor Liner, and undercoated with 3M Professional Grade Rubberized Undercoating.
Brakes: Offroad Design stainless braided 33 inch extended brake lines.
Engine: 6.2 Detroit Diesel
Transmission: Turbo 400 with Tilden Motorsports Pro Series transmission pan.
Transfer case: NP208 with Dodge output shaft and flange to eliminate the slip-yoke.
Driveline/Driveshaft: Custom double cardan 1350 rear driveshaft.
Steering
Front Axle
Rear Axle
Front Suspension
Rear Suspension
Other/Miscellaneous Modifications:
Extra Parts:
Known Issues:
Steering
- DIY4X Crossover/High Steer Kit
- Offroad Design Steering Box Brace
- Barnes 4WD Offset One Ton Tie Rod Kit
- Crane Kingpin Spring Eliminator Kit
- Borgeson 935 Steering Shaft
Front Axle
- Dana 60
- 4.56 Gears
- Riddler Manufacturing Differential Cover
- Yukon Forged 1350 Yoke
Rear Axle
- 14 Bolt
- 4.56 Gears
- Detroit Locker
- DIY4X Pinion Guard
- Crush Sleeve Eliminator Kit
- DIY4X Backbone Truss System
Front Suspension
- 3 inch Tough Country HD Leaf Springs
- Rough Country N2.0 Shocks
- Offroad Design Front Upper Shackle Hanger Kit
- DIY4X 6 Inch Shackles
- DIY4X Weld On Adjustable Bump Stops
- RuffStuff Specialities Bump Stops
- WFO Concepts Zinc Coated U-bolts and Plates
Rear Suspension
- DIY4X Shackle Flip Kit
- DIY4X Shock Inboarding Kit
- Offroad Design U-bolt Reversal Kit
- Dakota Digital VHX Gauge Cluster
- Auto Meter Diesel Tachometer
- Aluminum Radiator
- 12 Volt Conversion
- Jegs Chambered Deep-Tone Mufflers with Turndowns
- New Urethane Dash Pad
- Trimmed Front Fenders
- The majority of undercarriage has been repainted.
- RCI 17 Gallon Fuel Cell
- LED Headlights
- Offroad Design High Clearance HD Engine Crossmember
- Hidden winch mount behind front bumper with hawse fairlead.
- 12,000 lb Badlands Winch with Synthetic Line and Factor 55 ProLink.
- In-cab Winch Controls
Extra Parts:
- Classic Industries Weatherstrip Set
- Speedway 910-23105 Heavy Duty Aluminum Powder Coated Transmission Cooler
- DIY4X High Steer Hydraulic Assist Cylinder
- DIY4X High Steer Hydraulic Assist Mount
- DIY4X Hydraulic Assist Steering Box Cap with Spanner Wrench
- DIY4X Tie Rod
- (4) DIY4X 7.25 Inch Shackles
- (4) DIY4X 4.5 Inch Shackles
- Offroad Design 25 Inch Stainless Braided Front Brake Lines
- Rough Country 6 inch Lift Kit (includes everything except for the shocks which are currently on the truck).
- RuffStuff Specialities 14 Bolt Disc Brake Brackets
- Stock Wheels and Tires
- Stock CUCV Rear Bumper with Pintle Hitch
- Right Stuff Stainless Steel Transmission Cooler Lines
- Fuel Pump
- Fuel Filter
- Various Polyurethane and Rubber Suspension Bushings
- Various U-Bolts
- ACDelco Glow Plug Set
- Extra Glow Plug Controller Circuit Board
- (3) Extra Glow Plug Relays
- (4) 40 Inch Tire Covers
- Neapco 2-1153 Universal Joint
- Spicer 5-178X Universal Joint
- Spicer 5-153X Universal Joint
- HP4110 Parking Light Bulb Socket
- (2) Black Shock Boots
- Radiator Cap with Sacrificial Anode
- Radiator Drain Plug with Sacrificial Anode
- Gasket Set
- Brand new battery tray with support
- Set of Offset 1 Ton GM Tie Rod Ends
Known Issues:
- Interior door panel on the passenger side is missing.
