1 - 9 of 9 Posts
1985 Chevy 1 Ton 4x4 86k miles
6.2 Diesel, Dana 60, 14Bolt W/ Detroit Locker 4.56 Ratio
Turbo 400 Trans, NP 208 Transfer Case
Ex Military Truck M1008
8800 GVW, Rear Pintle Hitch
Fresh PA Inspection Good till 8/08 :)
Lots of new parts......tailpipes, Batteries (5/2005), headlamp dimmer switch, rear brakes/wheel cylinders, tie rod and tie rod end, both drag links and adjusting sleeve, steering stabilizer, tires are over 3/4 tread remaining, headlamp, rear driveshaft and u-joints, belts
Has been converted to 12 volt starter
The truck will need engine oil cooler lines because they leak
There is some rust in the cab corners However the floor and both rockers are SOLID. The bed floor is solid as is the bed sides. There are some dents and dings in the body from the military.
Asking $3500 Call 570-992-7230 or 973-464-0918
Follow this link to see pictures
http://s235.photobucket.com/albums/ee318/lookin4mud1/
1 - 9 of 9 Posts
