1 - 12 of 12 Posts
I have a 1985 Toyota 4Runner I need to sell. It is a fuel injected 22-RE, and has the solid front axle. I have just recently put a Trail Gear knuckle rebuild kit including wheel bearings on it. It also has the Trail Gear hi-steer kit on it. Only leak is power steering. It is leaking from the cooler hoses. If I need to I can fix those. It is regeared front and rear ring and pinions to 4.88:1. 32" Bridgestone Duelers ATs with 3/4 or more tread left. Runs great. Previous owner replaced the cluster, so the mileage is off on the current cluster. Current reading is 207,000 miles. Old cluster had 176,000 miles. I dont know when it was changed. Truck runs great, gets 22-23 mpg most of the time. It has a new battery. New tailpipe and muffler. New speakers all the way around. Great sound system. Just replaced a ujoint in the rear driveshaft. I did some body work to it, and its not perfect, but looks a lot better than it did. I did NOT use excessive bondo. Most rust holes were ground out and patched with fiberglass, and bondo'd smooth. Brand new paint job. Great daily driver. The only reason I am selling this truck is so I can buy a tow rig for my suzuki rig. Borrowing the dad's sucks.
If you have any questions or want more photos of something in particular, give me a call. 336-406-5269. My name is Adam Rogers. I am asking $3,000 or the best offer. I am in Winston Salem, NC.
it has factory ac, but i have never used it. when i bought it, it didnt have a belt on the compressor, and i havnt bothered to put one on to see if it works.
BUMP Someone make me an offer, needs to go this week!!!! I'll consider any offer.
wish you were in cali, does it have a lift on it? wanted to know cuz you have the highsteer on i and was wondering if you could run that without a lift?
Bump for a killer deal...
1 - 12 of 12 Posts
