1 - 3 of 3 Posts
Got conversion kit from trail gear put everything in changed out the load sensing proportioning valve eliminated it put a aftermarket proportioning valve with a 2 lb residual valve new master cylinder to 1 inch bore and still initially pedal goes to the floor Pump It Up it gets nice and hard and stiff to brakes work and then you let go of the pedal and then about a minute later the pedal goes to the floor again what could be wrong
1 - 3 of 3 Posts
