1 - 9 of 9 Posts
This is my first build thread and first build in general so bear with me lol. 23 years old, Long Island, NY. I picked up a 1987 soft top jx and started to tear it apart. After realizing the body was too far gone I decided to source a new body.
Started by plating the frame with drzfab stiffeners and 3/16" plate everywhere else. 4.3 vortex mounted which will later be leaving for a 2003 5.3 lm7.
3116667
3116668
3116669
Don't mind my welds. first time welding was on this thing. haha. I get better don't worry馃ぃ
3116670
Discussion Starter · #2 ·
3116671
I picked up an 87 tin top that has seen better days but for me... perfect!!
3116672
and with just my luck, it flies out of the pickup bed at 65 mph. shit'll buff out.
3116673
knocked some dents out and there she is. trimmed the frame little in the front. and sneak peak of the rear which you aren't supposed to see yet...
Ruffstuff 48" dual mount trailing arms
3116675
I wanted to add this is, I originally planned on 1999 f250 sterling and 03 f350 d60, found a fresh set of 2011 SD axles and I jumped on them. 4.88 gear is lowest I can go on the 2011s but I got a sweet deal, so we add more HP
3116676
old body..... but I had a buddy over at CrawlWorks Fab design me something personal for my rear truss and he killed it! TMR trailing arm lower mounts and Artec high upper mounts.
3116677
3116678
Some welds
3116679
uppers and lowers tacked on. upper links welded. 2x.25" DOM tube all 6 links ruffstuff 1.25" helms and bungs. Ruffstuff sterling cover which is BEEF and Artec gussets 60 degrees total rear triangulation. Anti Squat at 99% or 70% depending on what driving ill be doing. uppers and lowers both adjustable both sides, and pre-checked. I used a link calculator from one of the members on this board.
3116680
3116681
3116682
3116683
rockers were trashed so I cut a plate of 3/16 and lined it around the door frame on the inside, on the outside I welded 3.5"box tube for the sliders, will be turning into boat sides. body hard mounted to the frame.
3116684
3116685
ruffstuff 3 legged brackets
3116686
will be notching for 4 link
3116687
badass shot while measuring for link brackets
3116688
first test with 38s
3116689
these are chevy wheels laying where they'd end up. only to check for interference on links since their 18 wide and Im running 15 wide
3116690
test fitting Artec full hydro mount with my truss, that bridge doesn't line up properly so ill have to make something there. getting ready for full hydro. 4 links installed, sorry didn't take too many pics during this. 45 degrees of upper tri and 10 degrees of lower. 55 total triangulation. 72% antidive. its hard getting numbers where you need to be on trailing arm rear setup and lcg on 43s lol
3116691
3116692
some pictures. 4 linked front and rear full hydro 117" wheelbase, (goal) 21" belly, 43x15x17 mickey t Baja pro XS
12" rear axle link sep 10" front axle link sep
3116693
PSC 2.5x8 full system $1300 on Ebay here in 5 days, 4 bracket kit with the steering end kit, hoses, orbital. also ordered a custom psc steering column hex quick disconnect, and MOMO steering wheel.
3116694
mocked up, bracket bases tacked in, busted knuckle double shear hydro arms tacked on, might upgrade to 10" throw instead. we will see.
3116695
As much as my jacks could flex it but no link binding, will be running rear 1410 single driveshaft and JB conversions super short sye for the 241C, front wide open designs 1410 carrier bearing 1410 double cardon shaft.
3116696
other side
3116697
how do we feel? ordered 1 to check spacing, I kinda dig the $140 fake deadlock look lol.
hey Mate!
That is quite a fun thing yet tedious!
Where are you sourcing all the Gypsy parts from?
I know some guys in India who have been exporting all around the globe. If you want then can hook you up with them!
Best
1 - 9 of 9 Posts
