1 - 6 of 6 Posts
Picked this thing up off the original owner in 2007. Engine turned over, just some weathering from sitting out in the delta. Have almost every receipt to 1988. Trailer is a 1978 with new tires, lights, and wiring.
Then it sat in my backyard for 2.5 years while I traveled and wasn't home. I haven't touched the boat since the day after I brought it home. I pulled the lower end off to clean it, and bought a new fuel line. Both have not been installed yet.
Engine is a 85hp US marine Force outboard.
http://s213.photobucket.com/albums/cc111/GRM_Burglar/Boat/
Asking $1000 OBO.
Located In Morgan Hill, Ca.
Also have the ad at: http://sfbay.craigslist.org/sby/boa/1164183932.html
Offer #2:
The motor doesn't work, I'll give you $600 for the boat.
Response:
The motor worked when I pulled off the lower end should work when you put it back together.
Offer #2 guy:
My father says the force motor is junk. I'll have to put on a johnson. I'll give you $600.
Response:
You buying the force motor too. If you want to put on a Johnson Motor, thats on you. I can't accept $600 for the boat with motor.
1 - 6 of 6 Posts
