1 - 14 of 14 Posts
I can only think of a Mazda 5 speed, but I don't know if that would bolt up. But you should just swap to a 302 with the 5 speed. I don't really think the 2.9 is any good. A 4.0 is much better through.
As far as I know any tranny that came behind a 2.8, 2.9, or 4.0 Can all be interchangable. Advance adapters makes an adapter to put a T5 in as well. I forget what model is the strongest but i think it is the mazda one that is stated above not counting the T5
Matt
you have three choices:
mazda
toyo
mitsu
I have a mitsu behind my 4.0L and it is doing the job fine. if you are planing on doing a 302 swap do it now you will come out ahead. if you want to go 4.0L or like the 2.9L I would go with the mitsu or the mazda I think the mazda is an m50..something? it came in the newer mazdas.
In my experience, the Toyo Kogyo holds up better than the Mazda, and the Mitsubuishi are junk.
I'll be pulling an A4ld in the next month, but it sounds like you're in a hurry. Might be helpful if you aren't in an extreme hurry.
The Mazda M5OD-R1 is the strongest of the manual trannys that came in the midsize Fords. A similar version (M5OD-R2) is used in F-150s, also (this one won't bolt up though.)
The Toyo-Koygo and especially the Mitsubishi FM 145/146 transmissions had a lot of input shaft bearing issues.
A M5OD-R1 from a 4.0L will bolt up to your 2.9L.
Look in any 4.0 Ranger or Explorer (non SOHC) for this trans.
The 2.9 is a good motor, the only real weakness is if the cooling system fails (stuck thermostat, etc) it can crack heads easy. This rarely happens at normal op temps.
You can use an early Xploder tranny(4.0L specific), but the first gear is not as Low as the 2.9L version, thus its stronger, but less aggresive.
Head failure is a problem on '86-'87 2.9L's, by '91 when they stoped using the engine in production, the head problem was mostly fixed. The 2.9 is an Excelent engine. If your worried about over heating, put in a 4.0L radiator (bolts in) and you wont have problems.
you can find ALOT more information at The Ranger Station and at RRORC
If you swap in a manual for the automatic, you will need a computer modual for a manual tranny (I have one for sale) and the 3 pedal assembly for the clutch, as well as the master cylender and hyraulic hoses for the clutch.
The T-5 tranny comes out of mustangs.
good luck:D
I swaped a 4.0L into my 86 BII and the 2.9L radiator does the job with no problems. I just used the upper hose for the 4.0L and the lower hose from the 2.9L. mine never goes over 190.
you can put a T5 behind them but you have to get the adapters from Advanced Adaptors. Other wise you stuck with that tranny, you can also get an auto c5 out of an 84 bii but they were rare too.
1 - 14 of 14 Posts
