1 - 9 of 9 Posts
1992 Jeep YJ Custom.
This was a project i worked on for about 5 years. I am selling because i would like something that can seat 4 people.
**did some thinking and decided i would consider some trades on this.
only these though : FJ40, FJ60, 2010+ 4Runner, Land Rover Defender 90/110
thanks for looking!
SPECS:
Engine/Drivetrain:
-2001 5.3L Vortec V8 with custom air intake (about 150k on this engine)
-4L60e Automatic Transmission (about 5000km on the rebuilt transmission)(rebuilt and upgraded by all-o-matic) (beast ring, heavy duty parts, deeper transmission pan)
-Stak 4x4 3 Speed transfer case (5000km)(1:1, 3:1, 5:1, driveline E-brake)
-Dana 60 front axle (hi Pinion, High steer with custom steering arms, cylinder assist steering, 5.38 gear, Arb air locker, Disc brakes)
-14 Bolt rear axle (5.38 gears, arb air locker, disc brakes, custom ladder(anti wrap bar))
-Custom Driveshafts front is a double CV extreme angle shaft rear is a double CV, these driveshafts can handle the power and tires
-HD aluminum radiator
-Artcarr shifter
-39.5" Irok tires with balancing beads (can go 110km/h without wobble)
-16" aluminum wheels
-full SS exhaust with magnflow mufflers
-O2 sensors on each side
-engine driven air compressor with oiler,filter, and coescaling filter
-lockable front axle hubs (warn)
-aeromotive A1000 fuel pump
-billet fuel filter
-AN lines and hoses
-Battery trickle charger underhood
Body/Frame:
-absolutely no rust on this Jeep
-custom flat bed with swing down tire carrier and hi lift jack
-frame completely sand blasted and primed/painted
-underbody blasted and covered with bedliner (underside body and fenders)
-body blasted and rust removed, dents fixed and then primed and painted metallic green
-all nuts and bolts and hardware is new
-front grill replaced with a TJ grill
-custom tube fenders front and back
-custom headache rack and lightbar
-custom front bumper with warn m8000 winch (controlled from inside cab or out)
-custom heavy duty running boards (these will never get damaged)
-custom rear bumper with tow hooks and hitch
-all lighting LED
-underbody lights
-HID headlights and 5 top lights HID and 2 large front lights HID
-rear facing work lamps
-oak flat bed with SS trim
-air tank under bed
-removable mud flaps for off road
-removable sway bars
-rear aluminum boxes to store off road gear
-custom net for holding stuff to bed (comes with anchors that havent been installed)
-32 gallon fuel tank
Interior:
-completely custom interior
-corbeau seats and 4 point harness belts
-custom center console for switchs, shifter, t-case shifters
-floor covered with bedliner
-autometer gauges (speed in km/h, tach, clock, fuel, air pressure, oil pressure, oil temp, trans temp, voltmeter, front and rear diff temps)
-dual battery setup
-CD player with infinity speakers
-trailer brake controller
-momo steering wheel (adjustable)
- interior LED lights
-map lights
-floor matts
-custom sun shades
-CB radio (antennas not hooked up yet)
-custom heaters (one heater blows the defrost the other can be aimed at side windows or towards body. blow very hot air, downside is it can get warm in summer)
-power window conversion (passenger window is slow coming down may need some work)
This truck has had all fluids filled with Amsoil. Everything is in top shape on this truck. The only thing that may need some attention is the battery system. something drains them over a long period of none use.
This truck runs very well and gets around 12-16MPG which is quite good for its size!
This truck is always turning heads and is a one of a kind.
I am not looking for any trades at this time. If that changes i will update the ad. if the ad is still up the truck is still for sale. Please do not low ball me, you will get no reply.
I am asking $25000 for this unit.
thanks for looking and i have more pics i can send to interested people
This vehicle is located in Saskatoon Saskatchewan Canada
It's a bit of an illusion because its taken from a lower angle up. It doesn't hit at all in any way.
I had a ram that was too much stroke so I put a sleeve on it so it wouldn't put too much force out and bend it.
I can post some more pics with the steering each way for you if you'd like!
Also price drop to 25000
Discussion Starter · #9 ·
I have decided i want to see if anyone wants some parts off this rig.
I want to keep the axles and driveshafts and steering but other than that anything goes.
would like to sell the engine/trans/t-case all together
would like to sell the body all together with the frame.
wont separate the tires and rims. or split up.
i will put a list together of all that is available.
email or pm if you have any interest in anything.
1 - 9 of 9 Posts
