1 - 3 of 3 Posts
3108477
3108478
3108479
3108480
3108481
3108482
3108483
3108484
3108485
1993 Jeep YJ Sahara, 5.3 V8 LS Swap, $17,000 obo
Does not pass CA smog, You either need to have a workaround, license out of state, or have another title VIN that you can use. Is currently registered in a CA county where SMOG is not required.
5.3L LS swap V8
4L65E transmission w/shift kit
mated with NP231 transfer case with teraflex 4/1 kit
Sanderson ceramic coated headers 1 5/8" into dual 2.5" collectors
Flows into 3" single chamber flowmaster muffler
Ram intake from Novak
3 core aluminum radiator and 14" electric fan from Novak
Camaro flat belly Oil pan conversion for better ground clearance
Lokar Direct mount Transmission shifter
Novak transfer case linkage/shifter
Suspension:
1.5" military wrap Rubicon express leaf springs
Front shackle reversal from M.O.R.E Enterprises
spring over axle conversion with Ruff Stuff brackets
Rubicon Express shocks
Wheelbase extended 4"
Axles:
Wagoneer Dana 44's front and rear, 6 lug
Front has 5.13 gears with Spartan locker
Yukon Gear Chromoly axle shafts
Steering knuckles flat top machined for high steer Tie-rod
and drag link
1 ton tie rod end links, tie rod, and drag link from Ruff Stuff Specialties
Chevy 3/4 ton rotors and calipers
Rear axle has 5.13 gears with a Detroit locker
rear disc brake conversion
Cadillac El Dorado calipers with integrated parking brake (e-brake still needs to be hooked up) and chevy 3/4 ton rotors
Both axles have SOLID differential covers
Exterior:
Smittybilt front stinger bumper with d-rings
Smittybilt 8k winch
Smittybilt Rear bumper with swing away full size spare tire
Genright offroad 6" flat front fenders
Smittybilt 4" Rear flat fenders
Smittybilt Rock sliders
52" LED rooftop light bar
12" LED light bar on winch
2 - 3" LED light pods
LED headlights
Recessed LED taillights
custom recessed LED reverse lights
60" high lift jack
Interior:
Poison spyder full roll cage, powdercoated metallic silver flake
Corbeau Front suspension seats
Corbeau rear tumble seat cover
Corbeau 4 point harnesses on all 4 seats
Tub has been Raptorlined in black bed coating
GT grant leather wrapped steering wheel
LED backlit gauges (all work except Tach, need tach module from Novak)
Smity bilt black denim bikini top
Cobra CB radio and PA system with 4' firestick antenna
4-Kicker 6 3/4" speakers. Front centra pod, Rear crawl tunes trail cans.
Sony head unit, 5 channel amp with 10" JL audio subwoofer
Comes with hardtop and full doors
Wheels are 16x8 Allied beadlocks with 37" Super Swamper TSL's
1 - 3 of 3 Posts
