1993 Toyota extra cab
Clean Texas title
Just inspected sticker good till 12/12
BODY
Has 4Runner buckets and console
4Runner grill and lights
ENGINE
3.4L 5vze swap now with 165k miles (no CEL's) doesn't leak a drop of oil. This has always been a dependable vehicle, she never left me stranded
Downey headers, 2.5" exhaust, flowmaster 40 series
K&N filter
New Radiator
New heater core, heater works great!
TRANNY/T-CASE
r150 5 speed with stock chain driven case (both no leaks)
New clutch/flywheel assmebly
FRONT SUSPENSION
Ruf pack with 14" 5125 Bilsteins
Dana 44 (from older wagonner)
Cross-over steering.
4:88's with open diff. I also have a detroit ez locker which the pins broke and ruined the inner plates. I was told i could call detroit and order new plates and pins cheaper than buying a new one. Not too sure though.
REAR SUSPENSION
Shortened wheel base 5"
Bed bobbed 5" in front, 10" in back and dove-tailed 16" total.
Trail-gear 3" springs with leaves removed
Creeper Joints with 7" shackles
5125 12" Bilstein shocks
FJ TRD diff lock w/ 4:88's (working but not wired. I remove the 2cap bolts slide the pin replace the bolts and it's locked or un-locked)
TIRES
36x14.50 Swampers on 15x8 black rockcrawlers
or
315 BFG all terrains on 17x9 black soft 8's
NEEDS A TIE ROD It's double sleeved chromoly and I've driven with it bent for 5 years no problems. A little bump steer but i've just been waiting to upgrade to highsteer. So i aquired some MC heavy-duty tie rod ends and a tapped driver knuckle which will go with the truck.
NEEDS FRONT SHAFT WORK Its a 83 double cardan shaft without the grease sleeve. Since the sleeve was removed, under hard acceleration the shaft clicks. I've wheeled it like this for 8 years no problems. Never got around to makin a square shaft since it worked.
EXTRA PARTS INCLUDED
driver tapped knuckle
(2) MC heavy duty tie-rod ends
hub parts
Willing to drive it to you with-in reason and for the right price
Call/text/e-mail. Calls and text answered immediately.
$5,000 obo (915) 276-5948
Please check my craigslist ad for pics, can also send additional pics to an email address upon request
http://elpaso.en.craigslist.org/cto/2705589806.html
Clean Texas title
BODY
ENGINE
K&N filter
New Radiator
TRANNY/T-CASE
FRONT SUSPENSION
REAR SUSPENSION
TIRES
or
hub parts
