1 - 7 of 7 Posts
Asking $10,500 OBO - Open to partial trades for streetable rigs (CJ, YJ, TJ, XJ)
This is definitely not a show rig but this YJ will handle any Red at Rausch. Its built for function and its an incredible crawler - I've wheeled it for 2 years nearly every month.
If you're interested please email me at wiweasel at gmail dot com
Located near Harrisburg, PA
CL Link: http://harrisburg.craigslist.org/cto/4547235726.html
Here's the parts list:
1994 Jeep Wrangler Sahara
283,xxx miles on the body
Drivetrain
4.7L stroker motor (new O2 sensor just installed)
Brown Dog 1” lift motor mounts
K&N intake
Stage 3 clutch
AX-15 transmission
Atlas II 5:1, 32 spline outputs, 1310 CV yokes - I have spare 1330/1420 yokes and seals
Custom rear driveshaft w/ 1310/1350 conversion u-joint on axle end
Custom fabricated belly skid from A to Z fabrication. Skid drops and tubular tcase support holds tcase up as well.
Front Axle
1979 Ford Dana 60 High Pinion / King Pin
4.56 Ring & Pinion (freshly installed by previous owner of the axle)
Lock rite lunchbox locker
Ruff Stuff diff cover
1330 pinion yoke
stock axle shafts and hub lock outs
stock Ford dual piston calipers and new brake pads
Ford shock towers with TeraFlex shocks
Rear Axle
GM 14 bolt Full Float (believed to be from a military 1 ton pick-up)
4.56 ring and pinion
Detroit locker
1350 pinion yoke
Custom 4 link truss (made by previous owner of the axle)
Disc brake conversion (believed to be Ruff Stuff kit)
New calipers and pads (believed to be from a Chevy Dana 44 front axle)
Tires & Wheels
42" Interco TSL's on DIY beadlocks + matching spare
Front Suspension
Mountain Offroad YJ Shackle reversal kit
Rubicon Express reverse-wound spring over leaf packs
Rear Suspension
Custom single triangulated 4 link
All brackets from Ruff Stuff
All rod ends from Ruff Stuff
Lowers have 1 ¼” ends
Uppers have 7/8” ends
Arms are made from 2” .25” wall DOM tubing
Fox 2.5 Air Shocks 16” travel
Shock hoops from Jeeptubes.com
Steering/Brakes
PSC Full Hyrdo Steering Kit w/ double ended ram and TC pump
Steering cooler from Summit Racing
All new brake lines and hoses
Stainless braided brake lines from BDS (longest lines they had for YJ)
Wilwood adjustable proportioning valve
Master cylinder from 2000 Dodge Ram 2500/3500
Misc.
Boat side rockers from The One Fab
Full Comp Cut corner gaurds from Sniper Fabworks
New radiator from Summit Racing
New Serp Belt
RCI Fuel Cell from Summit, w/ stock YJ fuel pump installed, sealed up tight (no leaks)
Pioneer head unit with 2 10” subs and amp
CJ-7 Fold down tailgate
BestTop soft top (top has some tears and the top frame has seen better days. Its works but its on a trail rig)
Half doors with sliding glass windows
Many spare parts
CB Radio (freshly tuned)
Warn M8000 Winch w/ Synthetic line
ProComp rear bumper, Warn front bumper with winch protector
1 - 7 of 7 Posts
