1 - 3 of 3 Posts
I recently bought this truck. It had two rusted out freeze plugs and needs a new radiator. It’s been driven very little since I bought it, but has been started and idled in the driveway quite a bit.
When I bought it the check engine light wasn’t on. It is now and these are the stored codes. I threw a new MAP sensor at it because it’s cheap and easy :homer:
I was not surprised that the same codes are present after sensor replacement. I disconnected the negative battery cable for several hours. There doesn’t seem to be much about these codes with this truck on the net.
Any prior experience and guidance is appreciated.
1 - 3 of 3 Posts
