1997 Jeep TJ Stroker Motor w/60 $18500.
97 TJ RE 4.5 SUPER FLEX W/ADJ.FRT UPPER & LOWER ARMS
RE ADJ. UCA REAR & ROARK HD LOWER ADJ.
TERRA FLAT BELLY SKID PLATES
HD RUSTY'S TIE RODS
AGR STEERING
CURRIE ANTI ROCK
MORE SPORT CAGE
WARN HS9500 W/ X LINE
CUTOM BUMPERS FRT & RR W/ RECEIVERS & SPARE TIRE CARRIER
HAND THROTTLE
PIAA LIGHTS
BLUE TOP OPTIMA
KILBY GAS TANK SKID
290 HP 325LB TQ BALANCED & BLUEPRINTED
ENGINE HESCO .060 OVER 4.7 STROKER MOTOR BUILT BY LEE HURLEY
&CHUCK MCBRAYER OF HESCO. .470 LIFT DEGREE COMP CAM
80 PSI VALVE SPRINGS
HESCO 36 GPH INJ.
HESCO 60 MM CNC BILLIT TBS
ZERO DECK CLEARANCE 52CCD HEADS
TJ SHOWS 84K MTR HAS 2000 MILES
CSF 3 CORE RADIATOR 190 DEGREE THERMO
BODY
ROARK FABWORKS TUBE FRT FENDERS
PRP HIGH BACK SEATS W/ 5 PT. HARNESS
NEW SPICE TOP
TWO SETS OF SOFT DOORS
5 IROKS 36X13.50X15 90%
BACK SEAT
COLD A/C
OF COURSE SOME SCRATCHES AND ROCK RASH
BODY SLIDERS
AXLES
FRT DANA 44 HI PINION REV. CUT CTR SECTION W/ WARN INNER SHAFTS
WARN LOCK OUT W 5 ON 5.5 BOLT PATTERN CTM AXLE U JOINTS
ARB 4.56
REAR DANA 60 W/ STRANGE AXLES 1 5/16" THICK
ARB 4.56 5 ON 5.5
4 WHEEL DISCS
REBUILT AX 15 231 TRNS W/ TERA LOW 4TO1 32 SPLINE SYE JB CONV
TOM WOODS DRIVESHAFT 1350 GOLD SEAL U JOINTS
CENTERFORCE II CLUTCH
I DID NOT BUILD JEEP I BOUGHT IT AND NOW I HAVE FOUND ANOTHER JEEP I AM WANTING THERE ARE TOO MANY MODS TO LIST AND WAY TOO MANY DOLLARS SPENT HERE BUT IT WILL GO CHEAP OVER 32000 JUST IN PARTS
$18,500 CONTACT STEVEN 800 663 2522 OR 404 925 8515
PICS WILL FOLLOW
Rock Ready
HD RUSTY'S TIE RODS
AGR STEERING
CURRIE ANTI ROCK
MORE SPORT CAGE
HAND THROTTLE
PIAA LIGHTS
BLUE TOP OPTIMA
KILBY GAS TANK SKID
HESCO 36 GPH INJ.
BODY
NEW SPICE TOP
BACK SEAT
COLD A/C
BODY SLIDERS
AXLES
ARB 4.56
ARB 4.56 5 ON 5.5
4 WHEEL DISCS
PICS WILL FOLLOW
