Fuck no it's not easy, there is so much little stuff to deal with. It's easy if you have all the parts you know exactly where to cut and what to do. I have no fucking idea what the hell I'm doing but it is coming along. HaHa.
I started taking apart the rear and ran into some shit.
-The bolts that hold the leaf springs are 3/4" I think. So my leafs (2500HD) are not going to fit without a small fight.
-There is some kind of sensor (speed sensor?) on top of the Dana 70 (U, HD,???) but the truck also has a speedometer cable output to a sensor on the back of the tranny which one does what?
-The fuel tank is right up against the frame so I think I'm going to have to drop it to bolt up the front spring hanger on the driver side.
-The fucking wheel studs are 1/2":mad3:
What I'm thinking about doing is swapping it out to a 14 bolt. What I need to know is do I need that sensor on top of the axle? I don't think it has ABS but, I could be wrong (it happened once I don't want to talk about it
). The 14 bolt I have has 13" drums, the 70 in the truck has 12". The 14 has9/16" wheel studs matching the front, the 70 has 1/2".
Or taking it apart drilling out the hub/drum and installing new bigger studs.
What do you guys think?
