1 - 20 of 45 Posts
Located in northern Indiana
Will only ship if set up by buyer
Reasonable offers considered
Front Axles
Ford HP Dana 60 8x6.5 1978 Kingpin, Single Rear Wheel $1,100
Dodge Dana 60 8x6.5 Kingpin, Double Rear Wheel $950
Dodge Dana 60 8x6.5 1995 Balljoint, Single Rear Wheel $800
Chevy Dana 44 8x6.5 Heavy Duty $200
EB Dana 44 - 3.54 Housing with gears/carrier $200
Waggy Dana 44 6x5.5 1979 3.07 Non-cad, Passenger drop $200
Dodge Dana 44 5x5.5 1992 3.55 Flat top Knuckles $200
Jeep ZJ Dana 30 5x4.5 1998 Complete $150
Rear Axles
Ford 8.8 1997 3.73 Disc Brake, E-brake cables $225
Ford 9inch Complete $175
EB 9inch - Empty housing $150
Waggy Dana 44 6x5.5 1979 3.07 Offset Rear passenger $100
Chevy 14 Bolt 8x6.5 Ready for disc brakes $150
Dodge Chrysler 9.25 5x5.5 1992 3.55 Limited Slip $150
your location says oh / in what town r u in or what is nearest town to find u on a map
u say the dana 44 is hevy duty, what makes it a HD. and do u have any chevy dana 60s
Warsaw, IN 46580
HD D44 = 8 lug plus extra rib on housing
Chevy Front D60 got sold last weekend. Still have a dodge kingpin 60 should fit your needs.
Discussion Starter · #15 ·
thanks for the reply but u r 4 and half hours away and i drive a big truck thanks anyway
The reason I have Ohio/Indiana in my location is because I travel quite a bit. To give you an idea, Warsaw yesturday, Lafayette today. Cincinnatti over the weekend, cleaveland, columbus, springfield, dayton, then back to ft. wayne IN all next week.
That 4.5hrs doesn't seem so far anymore considering i'll likely be driving right past wherever you are... (your rock and hard place that is)
i drive a big truck
you should be proud of yourself :flipoff2:
Discussion Starter · #19 ·
do you ever come by canton/akron ohio
Man you just missed out considering I just arrived to Hudson, OH.. Likely you know where that is considering I drove past canton and akron to get here... Better luck next time i suppose...
southernpride658 said:
would you like to sell the calipers off the dana 44 ford
not likely. then I'd have an axle without brakes... I am usually able to find those at the local pick n pull pretty cheap...
jspivey said:
93 dodge 1 ton back axle is junked.....
Is yours a D70? Is the R&P still good?
If so it should work fine...
I could get it to attica next weekend without a problem...
1 - 20 of 45 Posts
