1 - 8 of 8 Posts
Ok, was going to move axle forward, but ol' papa bear put a stop to that idea. Now I will just be lifting the truck (82) 2, maybe 3 inches. Question is what, if anything, do I need to do to correct the steering. Dropped drag link? How much will that cost?
because the only reason for me doing any lift at all is to get more flex. I'm putting S-10 springs/longer shackles in the rear, and rear+front toy springs/longer shackles in the front.
I say just get the lift on first, then fix the steering;
My truck didn't have andything done to it with the old lift
I think it was between 2.5-3.5" of lift
Don't spend the $ on a drag link
maybe wait until the swap-meet and see what you can find there
someone may hae gone to cross-over and want to bail on the drag link
after fighting with my springs I wish I just could of spent the money on proven system
Your rears are going to be too soft for the front, when you use rears they should be 2-3"lifts from the rear, that way they will handle the extra weight of the front.
good luck Ben .....
and hope your u-bolts aren't a pile os rust like mine was
Originally posted by Ben:
<STRONG>And how would I go about recentering the wheel?</STRONG>
Just pull the steering wheel off and replace
it in the correct position. I had to do this
after about every wheeling trip until I did
cross-over. Good luck with your project, and
let us know how it worked out
<IMG SRC="smilies/smile.gif" border="0">
I have Old Man Emu springs (2.5" lift) on my 85 4Runner and am using the stock draglink. I have had this setup for 4 years and have no problems at all. For a mild lift your steering should be fine with stock components.
I will be doing crossover at some point, probably as soon as I break a steering arm or draglink.
Allan
"wait until the swap-meet and see what you can find there"
Yeah, thats what I plan on doing if I use a dropped drag link at all.
"Your rears are going to be too soft for the front, when you use rears they should be 2-3"lifts from the rear, that way they will handle the extra weight of the front."
I won't be using the rear springs as is. I'm using a couple leaves from the rear and a couple from the front. A few people on here have done that with good results. If that doesn't work I have a bunch of spring packs to screw with to get it to work! <IMG SRC="smilies/biggrin.gif" border="0">
"hope your u-bolts aren't a pile os rust like mine was"
U-bolt are fine, I cleaned them off and painted them the other day. No deep rust, and the plates are good too. I ordered my shackles for the front today, so now all I need to do to make all this a reality is make a trip to everett steel to get some square tube for my springs hangers, then put it all together! <IMG SRC="smilies/smile.gif" border="0">
1 - 8 of 8 Posts
