im wanting to throw two 4k winches on my toyota ( front & rear)... i am aware ill end up having to snatch block everytime but just curious if im crazy?
Aren't you on MGO?im wanting to throw two 4k winches on my toyota ( front & rear)... i am aware ill end up having to snatch block everytime but just curious if im crazy?![]()
that i am, guess i dont get the concept behind a winch?:flipoff2:Aren't you on MGO?
Check out Dirtydog offroad's subforum on MGO he's got 9K and 10K Engos cheap.
I'de run that.
how much does a toy weigh? Not much at all compared to the bigger guys running 8000-10000lbs winches.
Sometimes you just need the winch just to get yourself unstuck, then you can drive out with power.
EDIT:
Two 4000lbs should work.
i didnt see an issue but guess im wrong as usual!:homer:
Put a pulley on the axle and run the cable back to the frame so it doubles its line pull strengthjust think about this, a 2000lb winch barely sucks down my friends toyota leaf spring suspension, dont think a 4k would be good for more than a little 2 inch tug to get you moving in certain scenarios.
