1 - 6 of 6 Posts
I have a front and rear rockwell top loading axles for sale in chico.
they have been completely disassembled, cleaned, greased, spider gears have been welded, drain plugs have been welded shut, completely reassembled with the hubs flipped in, and spring perchs set at 31.5" for the front and rear perches have been set for your generic toyota frame width in the rear.
these axles are in good shape and completely clean.
the front needs new boots and boot clamps (axle shafts have been removed because they are the rapezza style shafts and are too weak for what i was going to use them for) if you would like the axle shafts i *may* be able to get them for you. the rear is ready to go.
Call me with any questions
530 321 9905
Any reasonable offer will not be rejected
Callen
do you know the width off hand? (wheel mount)
1 - 6 of 6 Posts
