first question is I want to make the axles a little wider for clearance and to be able to run bigger and wider tires
pros and cons on wich I should go with I know 3 is wide but I see a few people on the board are and have run them and they say no problems accept you will have to replace bearings every year or so and my power steering seems to be turning my 39's ok and I am going down to 35's for awhile then back to 38X14.5 most likely
what are your comments
and does anyone have a set of used ones I can buy or know anyone that does
the best price on the 2 inch ones I have found is 52.00
thanks
thanks
