I have 2 toyota steering pumps, both modified for higher flow by drilling out the restrictor plate. $75 for both + shipping or $40 each.
I also have a homefab'd reservoir that works good for full hydro if interested. It has the stock barb fitting for return to pump and 3/4" IN fitting. 1" nut/bolt for FILL and a vent tube as well. Holds around 3 qts. Triangle shaped. $35 + shipping.
Also have a custom made hose from the toyota pump output to SAE 6 for my old orbital valve. It is the stock hardline for about 8 inches then mated to hose with a compression fitting. About 2' long. $20
